Oscillating Spindle Sander
Oscillating spindle sander is not spinning. Stewards will look at it as soon as possible.
Check the oil level. I believe there is a sight glass at the back of the machine. Yes, it has oil! Curious question, did someone tip it? Both the oil and the drive belt are very unlikely to be the culprit as the machine is a heavy duty floor model and has not been used that much. If the machine was tipped or dropped on its side, is possible you’re going to have a big oil mess in the bottom of the cabinet. Also if that is the case, oil probably got on the drive belt.
Waiting on a 3D printed part before we can reassemble the unit.
