My print didn’t seem to have proper layer adhesion. Just posting here in case anyone has any obvious ideas. I tried leveling and am increasing the layer height from 0.3 to 0.2. Will update with the results
(Used the X-MAX with ABS)
Looks like pretty severe under extrusion. I’ve never used any of the printers we have so I couldn’t be sure the exact cause – could be poorly calibrated. What temperature was the hot end set to?
How did you get the xmax to extrude? It wasn’t even feeding last time I used it.
Qidi printer commands are a league of their own such as setting the esteps. Ill try and find the reference i had before and see if i can get it calibrated.
