FYI - future classes will be posted in Neon for sign up. For current class listings go to atxhs.org/atxhs-classes.
Hey Everyone,
This is the signup Post for the manual Milling class (Pre Req for Tormach Class)
The next class will be this Thursday the 17th, there is a 330pm and a 7pm section.
The class focuses on using the Rong-Fu 45 Vertical Mill but we also use a lot of other tools such as the DO-All Bandsaw, Sandblaster, Belt Sander, and grinder.
Things we will cover:
-Safety
-Parts of the Mill
-How to indicate a vise
-How to calculate proper machine RPM
-show you the difference between climb and conventional milling
-How to square a part
-How to layout a semi precise part with Dykem fluid and calipers
-How to center drill, drill, and counter bore
-How to mill a pocket
-How to use the Do-All Band-saw
-How to use The sandblaster
-How to make a leather insert on the Laser
You will get a cool little key-chain to take home with you at the end.
This Cost of the class is $100 and is a Pre-Req to take the Tormach Class.
Cash,Check or Venmo are accepted payment methods.
Some good videos to look through before you come to the class can be found HERE
Hey @r1b4z01d I held off on teaching the class because of the Fusion changes that were going in to effect. I am going to look through all the changes this week then set an official class up for next. Do you have preferred times for classes?
I hope I can make it to the upcoming class, but next week is another busy week for me, I can do it any time on Monday, Tuesday, or Thursday next week (19,20,22) If those days don’t work I will just have to wait for the next round, thanks
Sweet @iheartblocks I put you on the schedule for thursday at 3:30. @Fmartin if you would like to sign up I made a spot on the google sheet for the 5th.
