[Resolved] Large Laguna lathe down
The large Laguna wood large is down. The on switch is connecting intermittently. I will try to work on it this weekend.
Both midi lathes ready to use. They do not have an e-stop, which doubles as a master power switch on the large lathe. I will install a switchable outlet for each midi lathe, but in the meantime please unplug the midi lathes when you are done turning so that it is not left in a constant on state.
@Bob You’re good to go on the midi lathes. I just didn’t have time to do a full equipment check when I set them up the other day.
Thank you @CLeininger I will have my digital multimeter available for you manana.
