I need to get some sanding done on my cutting board and had 2 questions:
- is there communal 80 100 and 220 grit sandpaper that I could use or would I have to buy my own?
- is there a powered handheld sander at the shop to help speed things along?
There is a Black and Decker Random Orbital sander that takes 5" disks. I have seen a box of sanding disks before, but only once. You should provide your own sand paper. The sander also hooks up to the rolling dust collector. You just have to find the right adapter on the cart.
