What is the best way to print on moving blankets?
Will dye sublimation printing work?
Who does large-format (72" x 126") printing at affordable rates?
Sublimation is typically limited by the size of your heat press. There is a tool called an Easy Press made by cricut which is the love child of a heat press and an iron that can work for larger things. But it too has limitations,
Sublimation works best on polyester fabric, and is an additive process meaning you can only go darker than your base fabric. There is no white dye.
Our printer can accommodate paper up to 13”x51” but again, the heat press is the limiting factor
