The horizontal bandsaw was cutting very slowly today. I wasn’t certain of that judgement at first, because I was cutting a bigger aluminum piece than I usually do, but @mkmiller6 cut some material after me, something he’s cut before, and he agreed it was taking much longer. I didn’t go back to look at the blade, but I suspect there is an issue there.
(Unrelated side note: I ought to learn how to refill the coolant on that at some point.)
there is an extra blade in the stewards cabinet I think.
Just add water to the tank via the drain pain a half gallon max probably just look on the left side to see that it doesn’t overflow. No need to add any concentrate any time soon.
