Hello, I don’t know if this section is the right one to ask for help.
I have an STL file which I need to print in silver or gray PLA. Is there a way to go to the store and print it directly or what is the process to print it? I tried to post it here but as a new user I can’t post it.
This is the OpenSCAD code to generate the STL file:
$fn = 96;
// Size: 150 x 150 x 50.5 mm
// Inner cavity includes 1.5 mm clearance per face for adhesive felt/EVA lining
inner_w = 153.0;
inner_d = 153.0;
inner_h = 53.5;
wall = 3.5;
corner_r = 18.0;
outer_w = inner_w + 2 * wall;
outer_d = inner_d + wall;
outer_h = inner_h + 2 * wall;
module rounded_box(w, d, h, r) {
hull() {
translate([ w/2 - r, d/2 - r, 0]) cylinder(h=h, r=r);
translate([-w/2 + r, d/2 - r, 0]) cylinder(h=h, r=r);
translate([-w/2 + r, -d/2 + r, 0]) cylinder(h=h, r=r);
translate([ w/2 - r, -d/2 + r, 0]) cylinder(h=h, r=r);
// Rotated so the front face lies flat on the Z=0 print bed (prints with zero supports!)
translate([0, 0, outer_d/2])
rotate([-90, 0, 0])
difference() {
// Outer shell
rounded_box(outer_w, outer_d, outer_h, corner_r);
// Inner cavity (slides in from +Y rear face)
translate([0, wall/2 + 0.01, wall])
rounded_box(inner_w, inner_d + 0.02, inner_h, 4.0);
// Status LED dimple on the front face (-Y)
translate([outer_w/2 - 28, -outer_d/2 - 0.1, 14])
rotate([-90, 0, 0])
cylinder(h=1.2, d=2.0);
