I’m trying to set x-y home and I’m getting an error. I also noticed that the top right says manu.
I have tried shutting everything off several times to no avail
i don’t know how to solve this but I’m in the woodshop now and it would be awesome if someone knows and can help. @bwatt tried to help, but he didn’t know either.
I uploaded an image of the error on the console and Google said to press the high low button and the menu _0 button.
Best I could figure out, on further query is that the high low button is 0 and then the menu button is, well, the menu button.
After holding them down for awhile, it’s gone to “workpiece 2” mode. Not sure that’s what I want, but it did let me set x/y now and use toolset to set 0.
You are in absolute (machine) coordinate mode. You cannot set a zero in that mode, it is fixed. In order to get to workspace coordinates, there is button combination for that. I don’t recall what it is, but it is called out on the backside of the controller. Instead of “machine” you should get “Workpiece 1”.
