At long last, the Grizzly Bandsaw is hooked up to dust collection. It has a powered gate. All you need to do is turn the main dusty collector on, if it’s not on already. When you turn the saw on, the gate will open.
The Grizzly has two dust ports, do they’re is a splitter at the wall.
As always, clean the saw up when you are finished. Now, it won’t be quite as much work.
Also, check the dust collector bin and empty if over 1/2 full.
