- My lab is giving away a set of 3d printers and a good amount of filament.
- Three work, one is unknown, see details below
- We need you to take all of the printers and filament in one load
- We will not separate the lot. You must take it all.
- We are located near 360 and the bridge
- Full details after the images
Must take everything.
Location: Local pickup only in Austin, TX. You will need a truck or van and someone to help you load; I cannot assist with loading. Lab is near 360 and bridge.
Hardware Included:
UltiMaker S7 + Material Station: Dual extrusion, built-in air filter, camera, and 6-spool filament bay. Works reliably, with occasional TLC. Comes with a bunch of extruders, in various states of having been used.
UltiMaker S5 + Material Station & Air Manager: Dual extrusion, built-in air filter, camera, and 6-spool filament bay. Works reliably but needs more attention than the S7. It prints fine but occasionally throws a filament jam or balance error code. Usually clears with a reset, but I have had to replace the internal SD card with new firmware. The good thing about this ultimaker is that it’s fixable and accessible, but it requires some familiarity with the S-line architecture. The screen has a little burn out but not enough to impede use. Comes with a bunch of extruders, in various states of having been used.
MakerBot Method X: These machines are really well engineered. The machine works reliably. The chamber also has a filament drying mode. Includes 8 extruders in various states of use, and two build plate grip surface kits.
Formlabs Form 2 SLA Printer/Wash/Cure for parts: You should assume this does not work, but you might get it working. Not being cryptic, this came from the combining of two labs and needs someone to spend time with it to see if it works. Includes Form 2 printer, Form Wash, and Form Cure. This is untested, missing one power cord, and treated as a complete giveaway. No guarantees it works; consider it for parts, repair, or resin materials.
Consumables & Spares Included:
Parts: Selection of used and unused UltiMaker print cores (A and B types, 0.4 and 0.8mm) and X/Y calibration sheets.
Sealed Filament (Ages range from a few months to 2+ years
7 UltiMaker brand spools
5 MakerBot brand spools (includes Carbon Fiber)
9 Hatchbox 1kg spools (PLA, ABS, PETG)
~20x Mika3D 0.5kg spools
3x Formlabs color base, 5x resin cartridges, 3x pigment pouches (older stock, as-is)
Opened Filament: A large box of opened spools for project scrap or drying.
Terms:
Machines show standard wear from use.
Must take whole lot
spool numbers, names, brands, everything listed here, might be miscounted or misnamed.
