Calling all fusion 360 people, and vcarve too since I’ve had the same happen there
is there any way to re-order each individual cut within a series of cuts on toolpaths?
example:
I have a series of shapes being cut out, and the software puts them in this real stupid order, lots of needless time moving the spindle around without actually doing anything
this one isn’t really that bad, but a grid of holes I ran thru vcarve was a lot sillier
edit - turns out I found a solution:
check preserve order and re-select your contours in whatever order you want. where you click to select will be the initial entry point
