Has any decision been made about preparing the drill press?
I believe @mgmoore has identified the problem as the fuse board needing a repair. I’m sure he will chime in and clarify this. We will probably need @JohnWickham help with this repair or someone comfortable with it.
Great news. If someone posts more details here, I or someone else can get to work!
The drill press gets power but the digital display and it won’t run. This has bèn a problem in the past. It was working fine and then it wasn’t. I thought maybe a blown fuse. ![]()
It was working yesterday after I changed the fuse, but you have to hold the green button down until it starts and gets up to speed.
I know it wasnt working on Friday. I guess it was the fuse. Thanks, Ethan.
I’ve changed the fuse a handful of times. It’ll turn back on, but it keeps blowing. It definitely seems like it’s something bigger (imho). Fixing the fuse board sounds promising though!
