Hi all, I was using Dorian yesterday afternoon and couldn’t find the key to access the bottom tray. It’s supposed to be left on top of the machine. Maybe this was a case of being hidden in plain sight but I looked everywhere for it.
I may be missing something but, you should not need a key to use Dorian. What are you trying to do that would require you to open up any of the panels?
Michael
Hi Michael! There’s a door at the bottom of the front of the unit that lets you access the tray which collects pieces that fall through the grate. It’s useful for retrieving small pieces that may fall through after cutting, as well as for just generally cleaning up if you happen to have a lot of small offcuts that end up down there. It’s covered in the Big Lasers class, and there’s a note on the panel saying that the key should be on the top of the machine.
Scott
On Dorian’s right shoulder there’s a wooden tray; I last saw the key under all the hold-down hooks.
Thanks for responding. I’ll be in the this evening and will look for the key.
