4/19/2026 19:16:12 - Lasers - Tarkin
Problem Type: Equipment
Workspace: Lasers
Asset: Tarkin
Summary: Tarkin not working
Additional Info: Showing water prot error, BUT cooler is on. Restarted both units multiple times with no success. Also, April tried, too.
i checked it out this morning and found no problem
it is possible for a flow sensor to get stuck. this would trip the water prot error.
i saw it once in the past when the system had been off for a time and left dry. but just unstuck it and never saw a prob again
i did check the diagnostics on it and both were reading ok at the time. it should be ok to use and we can replace the flow sensors if there is any actual prob
