10/28/2026 12:26:47 - Woodshop - Laguna Swift CNC 5x10
Problem Type: Equipment
Workspace: Woodshop
Asset: Laguna Swift CNC 5x10
Summary: Z-Index changed between cuts
Additional Info: When the member’s second pass started the z-axis reset and a made a sound that seemed like resistance. when the tool lowered to make it’s next, deeper pass it was an inch or 2 above where it needed to be. No issue jogging the z to the top.
Neither Frank nor I encountered any Z issues. If the user can share more about their lead in settings or post processor, that would be helpful.
i also had this happen, however, it was after 4 or 5 usb stick swaps and a machine reboot fixed it.
there was no sticking or grinding noise, it was just a z that started cutting 75mm above surface.
i also witnessed the machine not boot properly a few times the other week. the person using the cnc had to turn it off and on 3 times to get the display on the hand unit to show text. it was on, but blank. even after waiting a few minutes.
i used the machine last week with no hiccups at all though. just say’n.
thanks!
