09/12/25 09:39PM Textiles - Heat Press
Issue type: Equipment Problem
Area: Textiles
Equipment: Heat Press
Summary: Timer on heat press does not work
Additional Info: The heat press does not power up if plugged into the timer. The timers 6 hours button was lit but still no power. If you plug the press in directly into the power strip it works.
AC timer confirmed to have burned out, removed from the area. New timers will be ordered. In the meantime, users should take extra care that they don’t leave the heat press turned on after completing their work.
